ben16v
fitting dual sensor to toad alarm
i`ve just purchased a dual microwave sensor for my toad alarm,
just wondering if anyone had any ideas on fitting?
i think it goes under the handbrake cover and then just wires upto the alarm??!
any ideas on if i need to reset the alarm after for it to recognise it??
any input much appreciated
cheers
ben
Your alarm should be able to take inputs from other sensors. Usually they look for a negative trigger. I can't speak for your alarm but GT alarms have a pink wire for extra sensors.
If you have ultrasonics fitted, I'd remove them.
Also I would wire it so it runs from a permanent 12volt supply. I have had false alarms from using the 'live when armed' output off the alarm itself.
Gavin
