sambo 0 Posted March 4, 2005 Noticed that my valver gets quite hot in slow traffic, oil gets up to 120 deg, fan only works on low speed, is my thermostat faulty? Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 4, 2005 Sounds like either the thermostat is faulty or you have a faulty temp sender for the fan. Quote Share this post Link to post Share on other sites
sambo 0 Posted March 5, 2005 Where is the temp sender for the fan? Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 5, 2005 Screwed into the radiator - halfway down the pass side.. :wink: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 5, 2005 Yeah, try the thermoswitch, GSF sell them and you'll need to remove the battery and use a 30mm spanner to fit, If you swap them quickly you should'nt lose much coolant. Quote Share this post Link to post Share on other sites
