dig776
Radiator/Coolant fan cover
Hi! any advice appreciated
Had day off today and because coolant fan was making funny noise decided to replace it. It had obviously not been done for a while cos the bolts in the plastic cover above the fan and rediator had badly rusted.
Replaced fan but had to cut through the cover bolts with hacksaw to get access to fan. Now cannot get the cover back on. Do I really need to get another? or can I do without one? :?:
arent there 3 bolts/ screws? just use 2 of them? you dont need it it just prevents stuff from hitting the fan, the neato foam in your engine compartment.
Thanks.
Yep three bolts but they had all rusted through so had to hacksaw them all off. Couldn't get to the bolt without sawing the plastic surrounding the bolt. If the only real concern is the sound proofing foam then won't bother replacing the cover.
Am a little anxious about the fan as the last time I had one go it caused the head gasket to go! which set me back £350!!!
cheers
