Bernie
Location of fuses S90 and S91
Hi, I'm troubleshooting the factory alarm from my 94 Corrado with the Bentley manual and one of the things to check are the fuses S90 and 91. After looking around for a while and with the electrical diagrams, I still can not find them.
Can anybody tell me where are they?
thanks.
Bernie
Hmmm - there are some above the passenger shelf behind the glove box but I thought they were for the ABS
Have you also looked above the fusebox??
Mostly alarm fuses are under the bonnet but not sure about Factory fit
thanks for your response. All the fuses I found are ok. Just found that the alarm is working but the door led light is not blinking. I will be taking the door panel out to check.
Thanks again.
Bernie
