willscott20
central locking pump please help
Hi I need a new cental locking pump but mine is missing so I cant get the part number off it. It is a vr6 1992 K reg there are two different pumps with part numbers
1ho962257g supposedly the later one
357962257 meant to be the earlier one
Can anyone help and have a look on theres its in the boot drivers side by the strut behind the carpet in a foam case.
If anyone can help it would be much appreciated
Many thanks Will
The Corrado up to the end of the 1992 model year should use the B3 Passat one, part number 357 962 257 A (using the North American EKTA). I think if you went to the breakers and grabbed on from a B3 Passat or a 1992 or older Corrado it will work fine. The foam cover is a Corrado only part though so the Passat one doesn't look like it will work in the Corrado.
Cheers, Dennis
