veritas137
knock sensor wires cut?
Ok, long story short my car has been running rather lean and pings a bit under hard acceleration and before I add a chip and pulley I wanted to track down the problem.
To complicate matters, when I got the car the front motor mount was nonexistant and it appears to have done a job on the wiring harness back by the intake manifold. Inside the bundles of wires I fond a special shielded bundle containign 3 wires, black, yellow, and white. Two of these wires were severed.
I fixed them finally yesterday and the car appears to be running a bit smoother says my butt dyno and in a short amount of driving I couldn't hear any pinging, but of course it could be my brain bloacking out the sound in hopes that the problem is fixed.
Can anyone verify that these wires are indeed going to the knock sensor and if so would they be related to my lean/ping condition?
TIA
