kid corrado
dash tweeters
putting some tweeters in the dash of my 2.0 16v 94 rado
does anyone know if the grills pop off and you fit them from the top or do you have to come from the bottom through the dash
cheers
for the door mounted ones is it the same deal
to take the door cards off. do i need to remove anythig from the door with a flat head screwdriver such as door opening surrounds
and handels
The speaker covers come off in the same way.
To take the door card off there are a few things to do:
Screw behind the speaker cover
Prise off the door handle cover to access the two screws behind
Screws in edge of door card
Unscrew the door pin
Then prise the card off and upwards and disconnect the electrics such as the electric mirrors, electric window switches and the speaker connections
There will be something I've missed ....
