G60Speed
Torque Settings
Just in the process of replacing the con-rod bearings in my G60, but i dont have a manual with torque settings.
Anyone know how tight the cap bolts should be??
Many Thanks!!
Needed replacing, the bearing material on no.1 was just getting down to the backing.. was a lot easier than i thought , once I had got the obligatory 2 x awkward sump bolts out (by the gearbox)!
Only hope that when I come to fire it back up, the knocking i had before wasn't the main bearings..?
Torque settings PG
Small end bearing caps 65nm with lock tight
Big end bearing caps 30nm + 90° times 2 with lock tight
Crank pulley *80nm with lock tight
