Rollyrob
Heater controls
I have a 1991 G60 with the sliding heater controls, I was wondering does anyone know if it is possible to put in the dial type controls
cheers
Greg
Sure can but you will have to change the centre section of the heater box for one from a VR6 Corrado or a B3 Passat. You will also need the control head for the heater with cables, wiring for the switch and a resister pack. After this you will also need a new centre section for the dash, ashtray, lighter surround and all the switches to the right of the gauge cluster as they are all a different size.
I think that is all you would need to make it work going from memory.
Cheers, Dennis
added to what Dennis says, you then also get a less reliable and generally naffer set of controls for all that hassle...
Stick with slides, you know it makes sense! :lol:
