biggrim 0 Posted March 22, 2005 Hello there! I've got a 92 G60 and I've fitted a boost return kit. Now, this pipe bit has a bit of a kink in it. Is there a special way to route this to get the kink out or is it just the way it is? Sorry about the guff quality pic, was on the phone camera. Any suggestions are welcome. Cheers Quote Share this post Link to post Share on other sites
Rossco 0 Posted March 22, 2005 I put mine over the top of the boost pipe. Then i cut the pipe so that my catch tank is just after the boost pipe, ill see if ive got any piccies..................................................................................................yep check here top right hand corner loon Quote Share this post Link to post Share on other sites
Guest Posted March 22, 2005 What did you do to the boost return hose from the bottom of the throttle body to the back of the charger? Usually this tube is left in place and the breather from the valve cover is still routed to it and the ISV is rerouted from the bypass tube to the intake hose on the boost feed tube. Cheers, Dennis Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 22, 2005 Is that a new pipe that came with the kit?? - mine just runs straight over the gear linkage to atmosphere... Quote Share this post Link to post Share on other sites
biggrim 0 Posted March 22, 2005 The one that came with the kit matey. I'm getting a catchtank made up just now so currently goes into an oasis bottle. Had tried putting it over but it just kinked the other way. Hmmmmmm If you can get some piccies up that'd be great. Cheers for yours Ross. You need to give that alternator a clean mate!!! ;) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 22, 2005 Hmmm.... yours looks alot closer to the boost pipe than mine for some reason grim! Quote Share this post Link to post Share on other sites
Rossco 0 Posted March 22, 2005 The one that came with the kit matey. I'm getting a catchtank made up just now so currently goes into an oasis bottle. Had tried putting it over but it just kinked the other way. Hmmmmmm If you can get some piccies up that'd be great. Cheers for yours Ross. You need to give that alternator a clean mate!!! ;) Just got a new alternator loon, its mint 8) Quote Share this post Link to post Share on other sites
biggrim 0 Posted March 22, 2005 Supercharged, can you post up a couple of close up pics so I can see the difference please? Cheers Quote Share this post Link to post Share on other sites
