Andi
17inch tyre PSI?
What should the PSI be for 205/40/17s on my VR6?
Same as if running on 15s?
Or a bit higher to stop hitting the rims in a big bump?
They're currently at 20psi front and 18 psi rear - but thats cos I've been driving in snow :)
Motorway driving tomorrow (well, today now :?) so need to put them back up - and wondered if they should be any different.
Thats a good question!
I'm not sure of the answer anyway, and I'm running 17's myself.
Come on someone must know some psi's!!!
30 psi all round works a treat , ive been running 17's at that for quite a few year's and had no tyre wearing probs , + thats what the tyre shop put's in them when ive bought new ones !!
That's a bit of a difference from the 36/32psi for 15s though.
Since the amount of tread on the road should be the same (i.e. 205) then I assume the pressures should be.
Depends how you like your handling too. Personally, I prefer it to be a little fiesty :)
I wouldn't always trust what some tyre-shop puts in. They more than likely filled the tyres when they weren't on the car - that is normal practice. So the pressue they get in the tyre is totally different to when each has a 1/4 of 1.5 tonnes sitting on it.
