Jonester
Fluctuating Revs
Upon starting my VR6 revs go from 500ish to 1500ish continually at idle. Then, when I drive her this continues but only whenever I come to a halt. The battery light is also flickering (brand new battery so no problem there) when the revs drop to 500 and she stalls constantly.
Any ideas before I let some halfwit grease monkey loose on her???
Jonester, Revving at idle (hunting) is usually, not always, caused by either a vacuum leak or an air leak. When the engine drags air in, possibly from a leaking inlet manifold gasket, it will display symptoms as you describe.
Steve, is there an easy way to tell if that gasket is leaking??
Dead easy - spray some WD40 over the gasket while the engine is running. The engine revs will pick-up if the gasket is leaking.
Don't be tempted to use brake cleaner or carb cleaner instead of WD40 - they're too flamable & may catch fire.
