CaiosG60 PWR 0 Posted June 28, 2003 I have a sqeeking and grinding brake somewhere. It only happens at low speed, pulling up to junctions, etc. I've had all my wheels off to inspect the pads and there all pritty meaty. Being a Golf G60 it has disks on the back and I'm convinced that this is where the sqeeking is coming from. It could be the brake disks but they don't seem to be warped. They are pritty warn though a few mm. Could somebody give me some more mechanical knowledge on brakes? I think the rear brakes are the same as those on non VR6 corrado's. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 28, 2003 Seized rear calipers are quite common on VWs... the pads will then become 'shiney' as dust does not have space to escape and fuses onto the pad under heat - making a sqeeling noise as the pad sits too close to the disc Good site for info... http://www.stoptech.com/technical/ Quote Share this post Link to post Share on other sites
sc16v 0 Posted June 29, 2003 First step is to remove pads clean up, cut a small groove in centre of pad, copper grease and replace, This will help stop dust build up and help prevent squeal. The discs shouldnt be warped, and if they are you should feel it through pedal, or the handbrake if you pull it at low speeds. :D Quote Share this post Link to post Share on other sites
steveo29 0 Posted June 29, 2003 make sure the grease only goes on the parts that DONT touch the disc Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 1, 2003 Cheers was going to take them apart but my Hannes manual say to replace the retaining bolts. I'm aware that the Hannes manul is a bit obsessed with replaceing bolts every time you undo any! :lol: Is it esential and should I just replace the rear disks while I've go the calipers off? Supercharged, You say that they may be seized? There defo not completely seized but how can I test if they are a bit seized? :? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 1, 2003 also if you replace the rear discs....its worthwhile replacing the rear wheel bearings :wink: Quote Share this post Link to post Share on other sites
