yalan 0 Posted April 17, 2005 I have no water coming from the rear wash. I hear the front bottle supplies front and rear washers, so guess there must be a blockage somewhere. The pump motor can be heard running. Anyone have any suggestions where to start looking? And I guess this isn't part of the MOT (due tomorrow!) cheers Quote Share this post Link to post Share on other sites
B4LJX 0 Posted April 17, 2005 got the same problem aint gott clue - would be good to find out Quote Share this post Link to post Share on other sites
G60Jet 1 Posted April 17, 2005 disconnect the pipe from the pump then see if its pumping then try and trace the problem Quote Share this post Link to post Share on other sites
yalan 0 Posted April 17, 2005 disconnect the pipe from the pump then see if its pumping then try and trace the problem well, the pump is pumping all the way to the wiper motor. The blockage must ber in the linkage mechanism somewhere. Tried to get the motor/linkage unit out, but it looks like the whole spoiler mech needs to come out too. Bah. Any suggestions for clearing the nozzle (other than a pin)??? And the rear wiper blade is falling apart too. MOT failure ? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 17, 2005 Block the pipe, remove the blade and motor, rubber grommet over hole - Job done! Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted April 17, 2005 no probs at all with MOT. Quote Share this post Link to post Share on other sites
