dinger657
headlights not working!
help! my headlights have decided to give up working, i have side lights and full beam but no dipped beam! they were working fine earlier, all of a sudden nothing, i have checked the fuses and they are fine, anyone any ideas?
cheers
matt
Do you have a replacement loom for the headlights? There maybe an in-line fuse on there which has blown... Mine is around the battery area.
Have you taken the fuses out and cleaned/reseated them - they tend to get a bit of surface rust from being in the engine bay...
cleaned all fuses, dim dip resistor not connected as im using an uprated loom, all been working fine for about a year and now nothing only thing to try is the switch!
The same thing just happened to me, i have an uprated headlight loom too!
Any advice would be appreciated!
Cheers, James
this happened to me , firstly check the inline fuse on the loom near the relays , then get someone to switch the lights on and listen for the relay to click
no click either bad connection or as in my case the relay is blown ( they do this if they get wet and the contacts corrode
for future ref if it is that , i got a length of bike inner tube slid it over the relays and fuses and tie wrapped it ...keeps it dry
