rs200f40
Need help identifying some wires on a G60
Hi,
I'm doing a 20VT conversion and am trying to identify some stray wires I've got left fron the G60 loom.
Can anyone help with any of these?
1.
Blue/White wire with a single shrouded crimp style connection.
Probably for a sensor.
2.
Brown/White wire with a single shrouded crimp style connection.
3.
Blue wire with a proper clip on connector (black, single socket)
For alternator perhaps?
4.
Red/White wire and a Red/Yellow wire with a proper clip on connector (brown, two sockets)
For throttle body ?
Thanks
Alan.
Hi alan,
Right,
The blue/white wire normally
found near the dist. is a spare
wire used for an optional oil
press. gauge,the wire goes to the fuse box.
The brown/white wire should be for
the fan/Temp. switch located on the left side of
cam cover.
Blue wire's for the Alt. signal to dash LED.
Brown socket's for fuel temp/pressure sender located
on the end of Injector rail,hope this helps mate.
Regards,Andrew.
