chaz g60
is there somthing missing in this pic???
dont know if there should be somthing on the right little outlet its on the right side of the engine, theres two little black outlets one with a coiled pipe on it one with nothing?
in the one pic its got a bit of white string tied to it
Looks like your clutch slave cylinder to me. One pipe & one bleed nipple.
No idea what the string's for though
just to bring your attention to it. shit hope i took it off
so nothings missing off that nipple then? nice name for a car part init?
Helio,
The 'string' looks like PTFE tape to me. If its wrapped around the bleed nipple - and on the nipple threads then the previous owner has had problems with clutch fluid getting past the treads.
PTFE tape is used by plumbers to seal joints on pipe connectors.
Your bleed nipple shouldnt leak fluid - but if you have problems engaging gears look at the nipple first - and see if it's leaking - cos that may be your problem!
