DEL VR6
Temperature goes sky high
But the fan will after-burn even if you disconnect the rad switch... albeit only on slow speed, which the manual leads me to believe is all there is.
innit?
Olly
ok then folks... it was the "thermostat" that i had replaced with a litre of antifreeze. Seems fine so far.
I think at the top Dr Matt may have been refering to me!
I had this shinanigans and would'nt beleive it was the water pipe to the back of the head, as it only showed one tiny white blob. Caused all manner of problems and turned out you were all right and i was a muppet!
Well said, Nick.
I just hope I can be as humble if (when??) it turns out that I was wrong not taking people's advice on my still dead 16v Passat.
Best wishes
RB
