NickVR6
K1 Racing VR6 Plug Leads
:cry:
With my hair still threatening to do a Bart Simpson at the thought of lunching £140 on a set of VAG reds, I bought these and got them today.
VAG style metal ends (plug end) look bang on, but attached to this is a rubber peice like the cheap black leads, only the rubber bit is much thicker than the metal. Catch my drift? So the lead tool will never get as far as the metal as it wont go over the rubber bit first!!!!
ALSO looking inside the metal end there is a rubber peice to grip the porcelin, and then the bit that actually clicks onto the plug top. If you can image that the rubber bit is only set into the metal by about 1cm you would end up with a 5inch long metal bit clicked onto the very top of the plug (hope that makes sense).
The actual leads were far to fat to go in the channels but thats fair doos as they are advertise at 10mm.
Not going to mention supplier as i assume they will be cool with refund.
Any of you guys found any aftermarkets that fit?
This is THE last time I'm bending over and taking it when buying bits.
It really is one thing after another. At this rate i'll be doing a re-make of Falling Down soon! :evil:
