Not_Aircooled_or_Taxfree
Stupid drips!
Please help me because me and water are going to fall out big time soon! Every time i clean our C i open the boot and do around the seals with the chamois, there seems to be an endless drip comming from the inside lightcluster on the boot? It is always on the drivers side. Is this another cunning VW thing that is meant to happen or is something leeking? If this is a VW thing should both sides be doing it?
Please help!
If you mean outside the rubber aperture seal on the short metal lip betwwen the outer rear lights. Yes, it gets in via the spoiler mounts /spoiler lift rods. The unit has drain holes inside the hatch ( nice!) and then it drops out via drain holes. Also water gets behind the number plate surround. Nuisance after washing the car if you want to wax it.
