CharlieHorse 0 Posted July 23, 2005 The drivers side rear side light dont work. CHANGE THE BULB!!! i hear you all shout. Done that, no joy. Indicator works, brake light works, but not side light. There is not voltage at the plug so that would suggest faulty wireing somewhere but i really dont want to start tearing my interior to pieces just yet. Any ideas? Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 23, 2005 Does the sidelight work on the drivers side? If not the fuse has gone. If it does work then you'll need a wiring diagram to get busy. Gavin Quote Share this post Link to post Share on other sites
CharlieHorse 0 Posted July 23, 2005 the front drivers side light works. So cant be bothered with trying to fix it. But its really doin my head in. Anyone got a wiring diagram? Quote Share this post Link to post Share on other sites
CharlieHorse 0 Posted July 24, 2005 Ok so the front drivers side light is weak, if it works at all now. Rear side light still dont work BUT if you put the parking lights on it does and the front side light too. Dodgy earth perhaps? Where do I look? Do all the electrics earth out at one point or all over the place? Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 24, 2005 Earths are at both sides of the boot. Try following the brown wires out of the clusters. Use the diagram for a mk2 if you have nothing else, most VWs are wired pretty much the same. Gavin Quote Share this post Link to post Share on other sites
CharlieHorse 0 Posted July 24, 2005 Cheers Dude! Quote Share this post Link to post Share on other sites
