kerrinmay 0 Posted July 29, 2005 I've done a search, but maybe not searching for the right words, but how do I get the door handle off so that I can get the barrel out? Do I have to take the door trim off to undo a bolt or something from inside? Quote Share this post Link to post Share on other sites
VR6 0 Posted July 29, 2005 Search for Keywords: You can use AND to define words which must be in the results, OR to define words which may be in the result and NOT to define words which should not be in the result. Use * as a wildcard for partial matches Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 29, 2005 Just one screw from the inside of the door (be careful as some are reverse threaded) You'll also need the door card off to uplug the c/l switch and plug a new one in.... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted July 29, 2005 http://corrado-club.ca/ferg/howtohandle.pdf Quote Share this post Link to post Share on other sites
