dannyc 0 Posted August 7, 2005 Hi my heater speed only works on numder 4, which is very annoying. any ideas? Quote Share this post Link to post Share on other sites
woody 0 Posted August 8, 2005 Use the search m8, but this is usually caused by the by the thermal resistor which is part of the assembly on the blower motor. All you have to do is replace the resistor. Have a search for "thermal resistor" Cheers Woody Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 8, 2005 http://website.lineone.net/~quigger/heater.htm That might help... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted August 8, 2005 or this......... http://the-corrado.net/.archive/forum/viewtopic. ... highlight= Quote Share this post Link to post Share on other sites
H8RRA 0 Posted August 8, 2005 you could have the knobs on wrong as they have different cut-outs and putting the wrong one on the speed control results in only speed 4 working - check the obvious before disassembling......i've done this before and thought it was a resistor or something :( Quote Share this post Link to post Share on other sites
Colley 0 Posted August 9, 2005 Could be the copper connecter behind is buggered, mine wasnt working at all and i changed that and now it works ok, apart from on 2, but better than nothing!! Quote Share this post Link to post Share on other sites
dannyc 0 Posted August 21, 2005 H8RRA i can't belive this actually works, i took them off and couldn't see a differene on the back, gave it a try anyway and it worked Brilliant! its not often things get fixed that easily Quote Share this post Link to post Share on other sites
