MillSpeed
Intermittently sluggish KR valver
The closed throttle switch definitely affects power on the 9A. If you open the throttle and press the switch it causes the engine to lose power and surge. What's different about how the 9A and the KR closed throttle switches work?
Disconnecting the throttle switch has defo done something to the ECU. The only explanation I can think of is that perhaps it was tricking the ECU into thinking that the throttle was closed hence its reluctance to advance the ignition when the car was revved.
