955matt
G60 knocking/tappet noise??
Hi,have got a strange one here.G60 with 110k on the clock started to make a light knocking noise at 2500-3000 rpm when hot!! No noise below this and no noise when cold.Noise sounds like it might be small ends but hard to get when stationary.Sounds like it is in the top half of the engine.
Only other thought is that the charger has never been looked at and is leaking a small amount of oil.Could the charger be starting to knock as I think this is about the same rpm (2500-3000) that the charger starts to work at? :?:
Any ideas
Thanks Matt :?
110k on a charger that's never been rebuilt is a LOT of miles. Sounds like your charger could well be the culprit. Hopefully, it won't be completely knackered. Have it checked/rebuilt asap.
