R1-Jay
Few questions
Picked up the corrado today and there have a few questions.
1) Has the full electric pack, sunroof/windows/mirrors etc, but for some reason the central locking doesnt seem to work, any ideas on what to check? i presume they all had c/l anyway!! has the pin on the fule cap to lock the flap like the mk3 golf
2) sunroof tilts, but will not slide, any idea on what i can do to clean/replace to get it working?
3) MFA shows 99.9 any idea where the sensors are to clean?
4) paint code, C is a '89 'g' 16v in a met blue, any idea where the paintcode is?
5) induction kit, is the engine the same as the mk2 golf 16v? if so, could i use one of those induction kits?
i'll post pictures up later on, but i need a few parts for it first!
Central locking pump could be dead.
Broken cable or jammed/worn mechanisms usually cause the sunroof to stop working.
The vacuum feed to the clocks is probably not connected. You can usually here it hissing under the dash.
Should be a paper sticker in the boot. The paint code will be on it. The same sticker is in the VW service book if you have that.
Use a panel filter, induction kits are pants. They let in hot air which reduces the power output.
Gavin :lol:
