Rick_ford55 0 Posted August 28, 2005 What would you guys recommend for this problem? The seal around my passenger wind is slowly coming undone outside the car although the glue is coming apart what would you recommend to stick it back down dont want to have to put it into a body shop as its mega bucks hard enough just to keep the thing on the road! And i'm looking for door pins that i used to have on my Mark 2 golf they were silver like the wolfsburg jobbies but had a little light on the top that went red when locked and then green when open anyone know where to get my hands on some? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 29, 2005 Rick_ford55, which seal is it? the lower one (the weatherstip) is about £40 from GPC but the one that goes round the window and is part of the door is about £150! Don't get Wolfsburg pins dude cos te Corrado was made by Karrman not VW! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 29, 2005 I've got the seals,inner,outer,frame 1,door 1...,you can remove the frame seal but it's a bugger to re-fit properly,spray contact glue(3M) is a good product when re-assembleing,go slowly and with patience you'll be able to do it. Quote Share this post Link to post Share on other sites
Rick_ford55 0 Posted August 30, 2005 Thanks guys it's only the bottom bit that comes off when i open and close the window, i'll try some of the that glue, know where i can get my hands on some? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 30, 2005 http://www.gpcvwaudi.com - give them a call tho as the website is more like websh1te! Quote Share this post Link to post Share on other sites
