PoorMansPorsche 0 Posted September 9, 2005 alrighty peeps my mate rekons you are supposed to use a torque wrench when putting a steering wheel back on?? cant see it meself but thought id check as im changing my 16v wheel for a vr6 jobbie at the weekend??? cheers brett Quote Share this post Link to post Share on other sites
MNuTz 0 Posted September 9, 2005 i never have mate, just a socket set should do the trick! oh, and making sure your wheels are straight when you put the steering back help too :D Quote Share this post Link to post Share on other sites
RW1 0 Posted September 9, 2005 The torque setting is 40Nm (30ft lb). So not too tight., just nip up and 1 hour on the 12 hour clock face forced. 24mm socket with short extension. . Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted September 10, 2005 Well RW1 is quite correct and it's a sensible question but come on, just change it and nip the nylock nut up using a little sense, i was surprised that anyone needed to ask this question but i suppose i shouldn't think like this if you have no mechanical reference at all. Chris Quote Share this post Link to post Share on other sites
PoorMansPorsche 0 Posted September 10, 2005 cheers, yep i dont have the slightest clue about mechanics !! the rado is the first car that ive ever tinkered with - all my other cars have been late - ish models that are better just sent down the garage. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 10, 2005 Like RW1 says there is a torque setting but it's no problem if you don't have a wrench, torque is not crucial as the wheel sits on a spline, just to it up as tight as you can by hand with a normal size ratchet (like you do with the wheel nuts and factory brace), 24mm as Mr One states. Chris VR6nos, the nut isn't Nylock btw... Quote Share this post Link to post Share on other sites
