kasman21
help me!!!alram is arming fine, but it doesn't lock doors
HEY GUYS!!
URGENT HELP NEEDED!!
went to alarm my rado today, with cobra full closure setup. it alarms fine but the doors dont lock!!!!any ideas what to do!!i cant leave it overnite like that!!
please any ideas guys wud be great
thanks
zak
Well to secure the car tonight you could try locking the car with the key. Mine has a clifford alarm and it still arms the alarm and imobilizer when you lock it this way.
This should keep the car secure until you can get it checked out.
Have you check the basic?
Fuse 16 - 10Amps [red] or Fuse 4 - 15 Amps [blue] or fuse 21 - 15 amps [blue] depending on year of the Corrado. (4 different C/L systems on C's, one with no fuse main panel row)
Fuse S52 - 20Amps [yellow] (above the fuse relay panel)
If not those, either the alarm output or the pump module in the rear offside of the boot need checking.
If the windows aren't working when you use the switches inside the car then you probably have an electrical problem which is also preventing the doors from locking. I think you should check the fuses as suggested in the previous post.
If the windows are working normally with the window switches then there could be a problem with the outputs from the alarm that operate the total closure of the windows and doors.
cheers guys all sorted it was the fuse above the fuse box out of sight!!!!!the yellow 20 amp one.
thanks allot for all your responses, much appreciated!!!!
zak
