Ronan
G60 1.9 Conversion
OK, not including pistons, what else needs to be done to a G60 to do a 1.9 conversion? I tried searching but I couldn't find anything.
Thanks
There are a few differant ways to carry out this conversion the only thing they all have in common is that the block has to be bored out but even the size of the re-bore vary's. Best advice is to talk to as many companys as possible before making your descision as they all have differant methods on increasing the cc's
OK, well since the work on my car has mostly been done to you then I will speak to you - how much to do the re-bore? And what other partsa apart from pistons do i need? I know sometimes you can increase displacement by using different rods, but as you're boring it out then does it use the same rods?
Thanks
