bix
1.8 gti head, on g60 pg block?
As above really, will it fit straight on, and will it raise the compression?
Ryan
Same casting I think but G60 has sodium filled valves. Although I have heard that on BV heads they just fit one piece stainless ones anyway.
The Compression is in the pistons not the head.
Gavin
hehe
Chamber Volume
The volume of the combustion chambers is the final factor in determining compression ratio. The larger the chamber, the more volume is added to the cylinder and the lower the compression ratio; smaller chambers reduce volume and increase the compression ratio
if it is off a pb eight valve it will fit fine, you just need to tap the m6 thrread near tha alternator in the front of the head to m8, and tap a thread in at the back for the bracket for the sender that attaches to the fuel rail
