Valver
VR6 diagnostic port?......
Guys
I have a VR6 in my Mk2 Golf (OBD1 engine from Passat). Now, we didn't put the diagnostic port in (thought we'd do it later...), and now the donor car/shell has been taken away from the breakers.... :oops:
Can I use any diagnostic port from any Passat/Corrado or does it have to be a VR6 one?......Does it matter which type of plug as I think there were two types ?...
Thanks for any help.
If you're stuck with wires when you get a plug, PM me.
Be better to get a 16 way later version as you won't need to buy / rig up an adapter with the VAG-COM lead's plug (16 way).
Try and get the 16 way plug with wire still in it so that you can terminal block connect upto the ECU 4 wire loom.
