lukeage
messed up my lights somewhat
Whilst replacing my rear light housings earlier i went on a random bulb swapping mission and like a total tw6t did not note what was originally where - this has resulted in no brake lights. I also found that the bulbs were either really bright screwed in one direction and dimmer on the other way. I figure the dimmer way of connecting is correct and the brakes utilise the second filament being the brighter one.
Could i have blown out a fuse? - or is there any funny combination that would put out the brake lights?, the bently manual states fuse 10 so i will check that when its gets light in the morning as i had to stop halfway through as it got dark.
Just seeing if anyone can give me heads up on something else i may have overlooked, before i have a second attempt in the morning.
Ta,
Luke
Brake/Side light is double filament 21/5w bulb.
Indicators, rear fog & reverse are single filament 21 watt bulbs.
Use the outside to work which then goes where.
