16vgt 0 Posted August 5, 2003 man i have the worst luck with my cars!! 2/3 days ago my rear spoiler was working fine!! today the thing goes up fine, but struggles to come down- sometimes even stops... what wrong with it?? its greased up so its not catching or anythng...anyhelp!!! Quote Share this post Link to post Share on other sites
slot 0 Posted August 5, 2003 mite be the motor check the electrical connections in the tail gate ?? :? Quote Share this post Link to post Share on other sites
16vgt 0 Posted August 6, 2003 ive had a quick look at the motor and connections/wires..everything seems to be fine... is it a common thing for this to happen?? i know alot of corrados have sunroof motor problems.. Quote Share this post Link to post Share on other sites
slot 0 Posted August 6, 2003 i've heard of the spoiler control box failing!! this is under the dash below the clocks :? :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2003 Hmmm, I doubt its the box as its still working (moving) but if you want to check it, its very close to the manual switch - you need to remove the plastic trim that covers the fusebox. Quote Share this post Link to post Share on other sites
