Ad2408
Help with backrest foam
Hi
Has anyone got the part number for the seat back foam on the normal Corrado seats? (Its that part that contains the two bolsters that hug your ribs)
Thanks in advance
Adam
No help with part number but there were two types available a while ago, but when i went to repair the back of my early seats i found that the steeler could only get me the VR6 version which incorporates the seat back foam as well as the shoulder bits and sides. After taking my early seats apart i found that i could not incorporate the seat back foam as the early seats the foam slots into a pocket and is not attached to the rest. So what i did was carefully cut out the seat back foam, slide it into the pocket and use the rest as you should. I am sure there is a guide on here somewhere
Just give the steeler a ring he will rub his hands with glee when you tell him what you want, I seem to remember is was about £50
Cheers
Woody
