daytona600
Help with ECU chip replacement VR6
Hi all, can someone tell me where the ECU is & what it looks like on my Corrado VR6 '93
I have bought an Advanced Mororpsport chip from eBay. I need to know if it is simply a matter of pluging in or is the old chip soldered in?
Of course my main problem is locating the ECU :oops:
Left mid side in the scuttle, tucked right up under the windscreen bottom. You will need to remove the plastic water flash shield in the scuttle to get at the connection plug.
Disconnect the battery earth first and it is possible to damage the unit if it still has power to it.
Should also point out that some VR's have the chip hardwired to the ECU board so a chip holder may need to be soldered in first...
Not sure if we know what year / chassis they changed?? RW1?
Are you sure Steve? Unless the very early VR's had them hardwired, I understood that they all had a holder ... ?
