old man
Oil pressure sensors
Can somebody confirm that the 2 sensors around the oil pump are white and black on a 1990 1.8 16v, as they have been changed due to the buzzer and flashing lights going off, problem is the light still flashes, this was done at a garage and I reckon the one nearest the block should be brown and it`s not the pump as the engine would be dead by now.
Hopefully a valver owner will confirm, but I think you have one BLACK sensor (1.4 bar, yellow wire) and one BROWN (0.3 bar, blue/black wire). Also can't remember which of the two, but a new one from a stealer will come in BLUE now. Confused?! :confused4:
HTH
welcome to the forum oldman :) , yes thats true "vr6dom" the top one is the 0.3 bar the bottom one is the 1.4 bar(yellow wire) , I changed the 0.3bar on mine and all was ok after that :) goodluck.
Cheers "vr6dom and task" I reckon I have to go to the stealer for the brown sensor as the garage got this from gsf many thanks
