matthewb1985 0 Posted December 30, 2005 dont know if this is in the right place but here goes.. my drivers side breaklight buld needed replacing on wednesday so changed it. yesterday i noticed that when braking my hazard lights are coming on instead of my breaks outside the car and also on the dash they light up when i break. another thing is that when i indicate both of the dash lights are flashing. also when i arm and disarm my alarm only the indicators down the drivers side light up. anybody have any ideas?? cheers Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 30, 2005 That bulb you just changed, try changing it again or at least test it with the bulb removed. Gavin Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 30, 2005 is it a double filament. I put a single one in my brakes once accidently. the front side lights came on when i broke. Dunno if this is similar prob. Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted December 30, 2005 its a double i checked that also did what h100vw said to no avail. the passanger side brake light works ok when i take the new bulb out. also found out when i put my hazards my side lihts flash woohoo!!!!! Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 31, 2005 You have got a short somewhere then. The place I'd check is around and underneath the airbox. The hot air feed can wear through the loom and create shorts. It happened on my mk3. Gavin Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted December 31, 2005 well i have sorted the indicator problem one of the brown wires had come out of the conector at the back drivers side. looks like a bunch of monkeys have messed witrh it probably when doing the alarm as all the wires are covered in insulation tape Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted January 3, 2006 i am now having to put new connectors onto the wires for the back lights as they are still going crazy. does anybody know if the metal connectors inside the block are avaliable to buy. went to the stealer to see if they sold new block connectors with them in but only sell the black plastic bit. also can someone tell me how many wires should go onto each terminal as i seem to have too many?? cheers Quote Share this post Link to post Share on other sites
