Stroller
Problem with Central Locking on Boot
When I operate the Central Locking on the Corrado using the key on the driver's door, the boot remains locked and can only be opened by using the key on it independently. I am sure that this did not use to happen, the central locking operating the boot as well.
Can some kind person help me out please?
Thanks!
theres a different setting so all the locks open from the doors, i think the lock on the boot has to be in vertical position for them all to work
Take the back cover internal panel off and check the actuating rod is connected to the lock mechanism and is moving it. I've seen one or two drop out.
The lock has to be like this - to work...
If the CL isn't locking/unlocking it, check the rod as RW1 says, sometimes the white clip falls out and sometimes the rod comes off the actuator as it's only held on by a plastic clip...
Thanks. just checked the lock, and it actually has to be in the horizontal position. All is fine now!
