olly elworthy 0 Posted January 6, 2006 cheapest price and where from? 8) Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted January 6, 2006 Dealer only! About £40-£50 if I remember rightly Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted January 6, 2006 that sounds a bit better cheapest i have found so far is £68 + vat,, just want to change it as car has done 80K and cant seem to get much timing on it when tuning,, Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted January 6, 2006 I have one with a torn part on the cable and it's causing issues..... don't bother trying second hand as they're all torn up (as I've found). Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted January 6, 2006 mine looks mint but i still wanna change it,, so i will defo be buying a new one Quote Share this post Link to post Share on other sites
W3RKD 0 Posted January 6, 2006 mine looks mint but i still wanna change it,, so i will defo be buying a new one have you tried testing it using the timing light method ? there might be need need to spend £48.00 Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted January 10, 2006 is that where you set the car running with the timing light on then give it a tap to see if it retards under knock? not tried this yet,, must give it a try,, car seems allot better with a fresh tank of fuel,, bought some optimax the other day and im not quite sure for that tank at least,,,, it was exactly what it says on the tin!! :? brother and i filled up at the same garage at the same week and cars were not right for teh whole duration of that tank of fuel,, seems back on track now though,, Quote Share this post Link to post Share on other sites
