godskitchen
Head gasket problems and MORE.......
Hello to all, its been a while, i have just moved to Ireland and have not had a chance to come on here! Anyway i will get to the problem!
I need to jump start the car EVERY day, it will not hold its charge, now i know this is either the Battery or the alty.
The car is usind WAY too much Oil, i am topping up every week and if i dont the engine sounds like a 20 year old MK2 FIESTA!!!
The coolant levels drop within 2 days causing the warning light to come on!
The oil filler cap has white GUNK on it!
Two of the HT leads (at the distributor end) when first turning the car on spark continuously untile the car is warm! (could be damp????) The car is also lumpy BIG TIME until its warm!
Just to add to my problems the heated seats have gone too!!!!
What i need guys is advice on garages in IRELAND, around the MAYO/SLIGO/leitrim areas??
Also how mush damage am i doing to the car by driving it around in its current state???
thanks in advance!!
Ring Tom in Fahy's Garage in Oranmore in Galway.
He is VST on here, failing that you could leave it to Martin Treacy in Enfield
PM davebirl on here and ask him where hewould recomend, he is in Sligo.
also there is an irish VAG forum called vagdrivers.net
