quicky1980
fuse box
are the fuse boxes all the same in corrado's? I only ask as in the future i may have an engine swap (most likely a 1.8t) and want to keep rewiring to a minimum.
also do the wires on early spec dash match late spec dash? thanks
the fuse boxes are the same on all corrados. The wires change on some of the corrados but for the most part they are all the same with minor differences. as for the engine swap you can do it as a plug and play but it requires the use of 3-4 different engine harnesses to do this. I think futrell motorsports has laided this out on the vortex but I'm not certain. I do know its possible because a local friend did this with a MK# 1.8T swap. Personally IO would just use stand alone and save the hassel and get more power. Or you could use the donar car's wiring and have a separate fuse panel from the donar car.
Pick up a bentley manual for the corrado and the donar car and your life will become much simpler
