madhatta
gear stick not returning to the centre (in neutral)
gear stick doesnt spring back to the centre position.... is this something major or just a litlle spring that needs replacing somewhere?
try sprayin a bit of lube on the selector part on the box itself(where the cables bolt on to) this is the part that controls the spring to neutral its possible it can be a bit stiff mine is sometimes but you can live with it really
Ross
