robbymac 0 Posted January 21, 2006 i got a new suroof and motor for my c and it works ok but when you close it it wont stop it carrys on going through the motion if you get what i mean say if you had it on tilt and you closed it it wont shut and stop it carrys on going and goes back my old c clicked when closed tried the search and i think the relay may be gone has any one else had this touble also can passat motors fit its an early corrado Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 22, 2006 not sure but i think its something to do with putting the motor on the sunroof mech when its in a certain position. Quote Share this post Link to post Share on other sites
robbymac 0 Posted January 22, 2006 what how many turns the cog turns on motor or you mean the actual sun roof Quote Share this post Link to post Share on other sites
woody 0 Posted January 22, 2006 right all you have to do is set the sunroof in one of the three positions ( normal closed position would be best, remove motor away from the sunroof and connect up the power connector. Press the button a couple of times and run the moror through its range and then set it on the middle setting. That should do it Cheers Woody Quote Share this post Link to post Share on other sites
robbymac 0 Posted January 23, 2006 right will give that a try weekend if i get back from spray shop let you know how i get on cheers Quote Share this post Link to post Share on other sites
