GazzaG60
Will 16v clocks fit a G60
16v clocks fit a G60?
My clocks as its a G60 only go 7k which is mre than fine for a G60 but i want a 7500-8k redline on the 16vt.
anybody know if 16v clock are a straight fit for G60 ones.
anybody got a set for sale?
cheers in advance
Gaz
If you go for a set of non-g6o clocks you'll loose the boost check in the MFA. I know mine doesn't work....
I'm not sure what clocks I've got but the fuel gauge is out and the revs only go to 7000rpm.
i know some are electronic and some mechanical. id expect id need the electronic ones.
loosing the boost check dont matter. I wont be running digi 1 and will have a 3 bar map sensor as i plan to run around 25psi
