GazzaG60 0 Posted January 24, 2006 16v clocks fit a G60? My clocks as its a G60 only go 7k which is mre than fine for a G60 but i want a 7500-8k redline on the 16vt. anybody know if 16v clock are a straight fit for G60 ones. anybody got a set for sale? cheers in advance Gaz Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted January 24, 2006 I think not! Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted January 24, 2006 is that a definate mate. im not too up on instument clusters and would hate to have to fit a tach thats non standard. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted January 24, 2006 If you go for a set of non-g6o clocks you'll loose the boost check in the MFA. I know mine doesn't work.... I'm not sure what clocks I've got but the fuel gauge is out and the revs only go to 7000rpm. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted January 24, 2006 i know some are electronic and some mechanical. id expect id need the electronic ones. loosing the boost check dont matter. I wont be running digi 1 and will have a 3 bar map sensor as i plan to run around 25psi Quote Share this post Link to post Share on other sites
