Rick_ford55
Engine mount
I've been told that i will probably need a front engine mount for my next MOT which is looming on the 10th of Feb, there is also grease leaking from N/S/R mount. Does anyone know how much these things cost? i read that the engine has three mounts if i am getting one done is it worth doing all three and if it is how much of my birthday money will i be using? :?:
All the mounts together should be about 100 notes ish if you buy from GSF or some place like that, i fitted mine myself so i cant tell you about costs, pretty easy job to be honest, only one that takes a bit of pissing about with is the rear engine one
