destructiv dave 0 Posted January 30, 2006 Driving along earlier, when my head unit switched off completely and a slight grinding sound occurred. My immediate thought with the stereo was that the X-relief relay had been activated, so not too concerned with that issue at the moment. Pulled over at my brothers (was nearby anyway) to investigate. Tapped the starter with a hammer and tried firing up, but had a proper horrid grinding noise, so stopped. Whipped out the starter and the ring gear on the starter shaft is wrecked. Now I have the option of getting a starter off a mate and trying that, refurbing mine (if poss) or bying new, but I don't feel that is really getting to the source of the problem. In the searches I have done on this, it keeps throwing up Ignition Switch problems...could this be a factor. Many thanks in advance, David Quote Share this post Link to post Share on other sites
samg60 0 Posted January 30, 2006 yeah ignition switch could be a problem, if it is brken and holding the starter engaged whilst driving, this just happened to mine an have trashed the starter motor. lost all lights at the same time. Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted January 31, 2006 Thanks for that. The stereo switching itself was so occassional that I blamed it on it being a Sony head unit issue...that was until today when I trashed my starter motor. Well seeing as I am dropping out the whole subframe and turbocharging the engine whilst doing a clutch change and renewing/uprating everything else that I can see, I may as well add a new ignition switch to my shopping list. Quote Share this post Link to post Share on other sites
