biggrim 0 Posted August 29, 2003 Looks to me like my rear spoiler is sitting too high at one side when it is down. Can it be adjusted or is it broken? I'll put some pics up this afternoon to give you guys an idea of what I'm on about. Thanks 8) Quote Share this post Link to post Share on other sites
JohnJ 0 Posted August 29, 2003 With the spoiler raised you will see the allen bolt heads on the spoiler pillars. 6mm I think. Also check the little rubber pad has not come detatched from under the outer ends. HTH Quote Share this post Link to post Share on other sites
biggrim 0 Posted August 30, 2003 Looks like the spoiler is bent upwards slightly on the drivers side. Doesn't quite go all the way down. Hopefully I can adjust it cause I don't want to have to buy a new spoiler :x Quote Share this post Link to post Share on other sites
biggrim 0 Posted August 30, 2003 Here's the photos I said I'd put up (eventually)! If I push it down it sits right but pops right back up. MAbye someone has opened the boot holding the spoiler at some point :mad: Any ideas guys? Quote Share this post Link to post Share on other sites
