.A.N.T.
Fuse keeps blowing after earth problems....
Have had a few issues with the earth on the C last week, these have been sorted by tightening the bolt that holds the starter in (it had worked loose!) Anyway, it happened on the motorway and the symptoms were the indicator lights on the dash were flickering.
Couldn't fix this out on the run so managed to get it home ok where it's been tighened and all sorted, but now this fuse keeps blowing.
It's the one second in from the right, which controls Cig Lighter, Spoiler auto control and the memory for the dashboard so all the clocks reset to zero when the ignition is switched off..
Does anyone have any ideas on where to start with this as I don't fancy pulling out all the wires behined the dash to check... :(
